Hello Guys i have done a fair few alignments now but every time I get the set up finished the car pulls to the left although I've used a well known string kit I think I have it boxed correctly but may need a more in-depth answer as to have top get it boxed perfectly to take measurements I always have to out the car back on the ramp and re adjust
Thank you
Alex @ Garage Twenty Eight
Any time I've had this issue it's been related to not securing the steering wheel sufficiently, so it's moved while adjusting tie rods.
How are you setting the steering wheel straight prior to alignment, then how are you preventing steering wheel/column motion during your alignment process? I find some tools for this don't work as well as I'd like.
