Aptiv (Delphi) CMC connector tooling
Introducción al ajuste del motor
4238 Vistas
Hello,
I'm looking for proper tooling for crimping the pins of an Aptiv CMC connector. This connector is suitable for GTS 0.64 and 1.5mm pins. In the datasheets they are mentioning to use the 33514306 and 33514360 crimping tools. The problem is, these are very hard to find. Someone can help me with maybe a tool which is functioning with these pins, and available in Europe?
Thank you! I will try this tool
Aptiv CMC connectors use different terminals from Molex CMC connectors. They are not physically interchangeable. We work with both brands. The Molex crimp tooling will not work on the Aptiv terminals.
Terminals are different but they both open barrel crimp style.
So, an Aptiv plug is usable on a Molex header and visa-versa, but the pins are not interchagable. Correct?
