ECU for my Honda engine.
Introducción al ajuste del motor
3275 Vistas
Hello what can you recommend to me as a newbie of ecu tuning.
i have HONDA F20b dohc engine. what's good ecu standalone or piggyback ecu?
but if piggyback is a less price then what is the good brand and easy to tune?
I'm excited to learn to tune for my first car. :)
What car is this, year and model?
honda accord 94 but the engine came from prelude. vtec engine
I would go with a Hondata S300 . https://www.hondata.com/s300 It's like a heavily modified stock ECU. So you get a lot of features of a standalone with a lot less work to get the car driving and running ok.
Going to suggest much the same thing - check with their tech support for best solution for your engine/vehicle combination.
You also could use an Obd1 P28 ecu combined with a Demon V2 emulator board. And use Neptune software for tuning. It's cheaper then Hondata s300, and as good or maybe even better then Hondata s300. Check Hrtuning.com
Thanks a lot, this keep me motivated to tune my engine hoping i can tune soon...
