getting into tuning
Introducción al ajuste del motor
2054 Vistas
hey, I have purchased the EFI fundamentals and both the practical tuning courses from HPA is this all I need to start learning how to tune and what are some ways I could be doing practical while following along with these, would bench testing be a good way as I have a few e36 Ecu's lying around ? let me know please. I'm quite serious about getting into to tuning. thanks
Hello Farhaad,
Welcome to HPA!
Yes the EFI Fundamentals course should give you the grounding and confidence you need to progress on to further learning perhaps through the worked examples and many other resources on here then its just a case of getting stuck in with whatever you have around you. Bench flashing could be good but you would need to know what you're tuning to so i would suggest getting some live data out of your vehicle as a starter.
