Ijectors Dead time
Introducción al ajuste del motor
1931 Vistas
hello all academy!! i have a engine 3S-GTE and im trying to find the dead time off injectors. p.n is 23250-74150.
Thanks!!
I have found two different tables, those injectors are 550 cc/min and low impedence (2 ohm). if used with a resistor pack, then the table would look like:
10V 1.24ms, 11v 1.04ms, 12v .87ms, 13v .75ms, 14v .64ms, 15v .55ms
if used with a peak & hold injector drive, then the deadtimes are very different:
10v .66ms, 11v .58ms, 12v .50ms, 13v .41ms, 14v .34ms, 15v .27ms
Data sourced from: https://injector-rehab.com/knowledge-base/fuel-injector-lag-times/ and https://injector-rehab.com/knowledge-base/published-injector-data/
David thenk you for your answer! im beginner at this and i really respect your prompt response.!thenks man frome Greece!!!!!
