Labour intensive Knock sensor locations
Introducción al ajuste del motor
1694 Vistas
What do you do for engines that have knock sensors in a very labour intensive location? Like completely underneath the intake manifold system like in most 6v toyota engines?.. Where and how else can you temporary setup for such situations?
Hello i picking you are meaning for temporary use like dyno etc and not left on for use after
I use a suitable position in the block or if this is hard I often use the head for audio use
on the dyno
Regards Ross
Thank you Ross.
