Older Link
Introducción al ajuste del motor
Módulo correspondiente: Diseño del arnés de cableado EFI > Sensores > Suministro de sensores
979 Vistas
I have an older Link g4 extreme and am about to wire in a oil pressure and oil temp sensor in it is an all in one sensor so 5 wires i believe. Do you guys by chance have the documentaion for this ecu so i can determine 5v supply in my ecu. Thanks guys you are legends. Luke
I think there may be wiring info in the help of the G4 PCLink software.
Of course, I think the real answer might be found by posting your request on the Link Forum for the G4 found here:
https://forums.linkecu.com/forum/17-link-g4/
The current wiring information within software still applies to what you're doing.
The only change from g4 to g4+ on the Xtreme was DI 9,10 pins can be used for CAN 2 instead if desired.
