Re flashing to install a turbo
Introducción al ajuste del motor
2292 Vistas
Is it enough to reflash the factory ECU for adding forced induction (turbocharger) method to a NA engine or do I have to standalone universal ECU?
It depends on how good the software you are using, I use Uprev for tuning charged 350Z and 370Z's which are NA from factory
Give us a little more information about your proposed project and we will be able to guide you more.
