Can the Ford torque tables be configured by road tuning ?? 2 years away from owning a AWD Eddy Dyno . Also I have never used Xcell software. So I would be lost there also .
Excel is an excellent tool to help you calculate some of the many formulas used in the ford PCM. . I recommend you learn it. Look at Excel, look at a histogram, they're the same. You can road tune the torque tables error free with out a dyno.
Do you know what Inverse Torque is? Inverse means the opposite or reverse.
y=1/x
x=1/y
That means if you open Engine Torque Table 1 and Inverse Torque Table 1, each cell location will have an inverse releationship with the other table. You need to your datalog to include ETC Torque Request, Engine Brake Torque, Desired Torque, Scheduled Torque, IPC Wheel Torque Error, Air Load, Mapped Point Weights.
What is the engine and vehicle and what are you using to tune it? HP Tuners, SCT, Cobb, etc ? Sometimes the flashing tool manufacturer will provide their own calculation Excel tools.
