What’s The Best Brand of ECU?
Introducción al ajuste del motor
1485 Vistas
My question is what would be examples of inputs and outputs ?
Inputs are usually sensors: Digital like crank and cam sensors, wheel speeds, and switches; or Analog like Oil/Fuel/Manifold Pressure, or temperatures like Coolant or Intake Air temp, or a driver knob.
Outputs are things controlled by the ECU, like Injectors, Coils, Solenoids, Relays and warning lamps.
There are also input and output communications for communicating with a computer for tuning, or an electronic dash or other device.
