Which sound is knocking ??
Introducción al ajuste del motor
2402 Vistas
Audio knock detection would take time to get use to knowing which sound to pick out of the recording . First time I have herd audio knock detrction . Seam to me it sounds as if knock is accuring when it sounds statically . In the clip kinda like an old stereo system when a thunder storm is near by and you get a crackleing noise in the speakers if listening to over air broadcast .
Although the HPA stuff is great, I found the recordings here handy as well - http://theknockbox.com.au/the-knock-box/sound-recordings/
