Bosch 150psi fluid pressure and temp sensor
Mantenimiento práctico del automóvil
Debate y preguntas relacionadas con el curso de Mantenimiento Práctico de Automóviles.
2169 Vistas
Hi,
I recently got a bosch fluid pressure and temp sensor for my build from Haltech.
i had a problem with the terminals getting stuck in my crimp tool and i am now left with no terminals/pins.
does anyone happen to know what part number the terminals/pins are and where i can find them?
I can’t find any info anywhere online
Any help will be greatly appreciated
Perhaps it's the Bosch BDK series terminals like shown in this connector kit.
https://www.bmotorsports.com/shop/product_info.php/products_id/1625
Here's a place in the UK with BDK terminals that might be able to help you:
https://www.3waycomponents.co.uk/Bosch-BDK-2.8mm-Female-Terminal-Use-With-Compact-Series-1928498056
Hi David,
they are not the correct ones unfortunately.
I think these are the correct ones - https://www.bmotorsports.com/shop/product_info.php/products_id/3311
problem is I can’t find anything in UK that is the same and i need them ASAP so getting them sent over from the US is not an option
They go in to this bosch connector -
https://www.bmotorsports.com/shop/product_info.php/cPath/109_136/products_id/4683
So if you follow the links to the associated parts, they show the terminal, and mention it's also BMW terminal # 12527545852, and is used in a C7 Corvette O2 Sensor -- you should be able to cross something with those starting points.
Tried cross referencing all the various connectors and got nothing this end. All links up back to the US.
In the end i spent a good couple of hours searching through all the different types of terminals on a uk supplier site and come across some that look identical. Have ordered and fingers crossed they fit
Does anyone know how to put the terminals in to the connector? I have finally crimped all the wires but the terminals do not want to slide in to the connector
this is the connector
[url=https://www.bmotorsports.com/shop/product_info.php/products_id/4683?osCsid=g88uadusobcp049pb2v7p7v0o7]https://www.bmotorsports.com/shop/product_info.php/products_id/4683?osCsid=g88uadusobcp049pb2v7p7v0o7
Did you remove the blue "wedge lock" face? The terminals should then go in, and the wedge lock re-installed to keep them from coming loose by accident.
