Debate y preguntas relacionadas con el curso de Mantenimiento Práctico de Automóviles.
What type of sealing grommets do you fellas use? I’ve passed wires through holes with grommets in the firewall before, only to find them loose fitting and worn from vibration and heat.
I have a 2” x 4” hole where the original molex type connectors were on my 70’s dodge ramcharger. My plan was to make a plate and use some type of modern sealed connectors to pass through.
This is the sort of thing you want
