Debate y preguntas relacionadas con el curso de Mantenimiento Práctico de Automóviles.
Would it be acceptable to have ignition coils grounded to the cylinder head and everything else (ECU, PDM, Battery) grounded to the chassis? I understand that Star Point Grounding means everything grounds to a single point, but I also have read that the ignition coils should ground in a place to have the shortest path to the spark plugs.
Yes, that is a good strategy. Some smart coils have two grounds, one or the signal (ECU), and one for the engine (Cylinder Head).
Thanks for confirming!
