132 | Using Datalogging to analyze Air/Fuel Ratio - Data Analysis
Preguntas del seminario web
2671 Vistas
Andre,
I like the MegaLogViewerHD method you described in this webinar and have found it useful in the past. I'm currently working on an ITB turbo engine (RB26) with TPS as my VE load axis and MAP as my Target Lambda load axis. Is there a way to set up the histogram table to be useful in this situation?
Thanks,
Mat
I'm not personally aware of a useful way of analysing the data for 4D mapped engines that use both TPS and MAP. As far as I'm aware you can only choose one load parameter in MLVHD which makes it tricky to get really useful data.
I was kind of thinking that was the case, but wanted to make sure I wasn't missing something. Thanks!
