Adjusting ride height
Preguntas del seminario web
1918 Vistas
Hi
Following on from watching the video- "Adjusting Ride Height Using Coil Over Suspension"
Honda S2000
Thinking outloud abit here, I've disconnected the anti roll bar as well as removing the spring.
I get jacking the car up until it hits the bump stop.
Then to check droop do I just let the wheel down and see how far it goes? I don't really get how you limit droop.
Usually droop is limited by the strut in a road car, a lot of the off road type buggies, truggies and trucks will also use a droop limiting strap to prevent damage to the pistons in the shocks at full droop.
As Steven said, it will be limited by the damper, which in a strut is internal, bump stops as sometimes found on 'wishbone' designs, or some other mechanical limiting device, such as a strap/loop.
Hi Najuad, as the guys have said above, the droop is controlled by the travel of the damper. This is not adjustable without modifying/replacing the damper unit itself.
