Wideband closed loop g4+
Preguntas del seminario web
2869 Vistas
Hi Andre. in the closed loop lambda settings, i only seem to have three options, off, stoich mode (narrow band), and stoich mode (wide band) there is no auto mode wide band, am i missing somthing, i have just downloaded the latest pc link, (im not online with my g4+ just in the software)
I've just run this past the guys at Link and they've informed me that the auto mode is locked out on the Storm and Atom. Other than that it should be available to you. What ECU do you have?
I have a storm guess that explains it. do you know if it can be unlocked with a upgrade or anything?
