Hey Everyone Introducing me and my Project
1825 Vistas
Year: 2006 Make: Chevy Model: Malibu Trim: SS
Hello all, my name is Scott, i own a 6th gen Malibu SS 3.9l.... ive owned it for about 8 months and so far Modifications are as follows; 87mm port matched throttle body, NiceCNC spiraled TB spacer, Ls4 to Ls7 Throttle body adapter, Full custom 3" Intake, LS7 Maf conversion, Port Matched 3.5l upper intake manifold (went away from the Intake manifold tuning valve), D585 Smart CNP conversion, 100% PNP conversion harness (made by me) for the cnp conversion, ICT billet coil pack remote location kit (each bank mounted on heads), taylor cable thundervolt 8.2mm plug wires, diamond fire e3.44 spark plugs, no cats, no mufflers, fully fabbed 2.25" full exhaust with Flowmaster flowFX resonator, Spawon dual core full aluminum radiator, dual 12" slimfans, rev 9 16way adjustable coilovers (from chevy HHR), Godspeed front adjustable swaybar links, retrofitted headlights, Front lip, rear diffuser, Drilled and slotted rotors, Aftermarket 6an transcooler, Lower intake manifold portmatched to upper, Aeroforce interceptor gauge, Odyssey cr925 battery, UEGO Wideband, HP tuners MPVi3 module (serial cable on the way to hook up fuel press sensor and wideband), Fuel Pressure regulator, Fuel press sensor and gauge, sure im missing some others but i think i covered most of it!!!! most of suspension and all have been refreshed as well..
Future plans:
sourcing my parts for low boost turbo setup, just wanting a lil pep with reliability and F40 6spd swap.. right now engine has unknown mileage it was replaced, but from looks internally its possible low mileage or just well maintained, transmission atm has roughly 26k on remanned jasper 4spd 4t65-e...
Thank you all for the opportunity to share my project!! :)
Welcome, that sounds like a fun project. Thank you for joining us!
Thank you!!
