Turbo'd lada issues
Ajuste práctico independiente
1518 Vistas
Hi All,
I have built a turbo charged lada niva running the standard 1.7L engine. Im having issues with getting it to ideal at a lean(14.0) AFR, and a slight hesitation under light throttle.
The details of the car so far are;
4 cylinder 1.7L
1050cc injectors
LS1 coil packs, its a even firing type
GT1752s Tubro off a Saab 9-3 running about 14.5PSI
Haltech Elite 750
Haltech Wideband O2 sensor
Cable throttle with a nissan n12 throttle body and TPS
any help or ideas would be greatly apreciated
  • BEFORETRACK-JULYU.csv
  • idle-20211012.csv
It's a little hard to give you a specific answer to this issue as there are a lot of potential causes. The usual issues I see that can give this sort of result are around spark energy. While normally poor spark will become more apparent at higher load, it can also cause issues at light load. I'd be confirming your spark plug condition and heat range is suitable, as well as the spark plug gap - Often reducing the plug gap can help. I'd suggest you check the dwell table to make sure this is correct for your LS coils too although this would almost certainly result in a misfire under load. Other issues that may cause your problem are mechanical - Poor valve seating just for one example. I'd recommend performing a leak down test on the engine to eliminate this as a possibility.
