Calcule SOI EDC17C50 BMW
2609 Vistas
Hello everyone,
I have my brain in compote at the moment,
I am polishing a mod on A BMW 116D 116ch F20 ECU EDC17C50
I explain myself, I try to take a maximum while respecting a certain calculation.
The car is full stock,
I give you an example to see if my development is good.
Map rail pressure: 65mg at 3000rpm I have a perssion of 2000bar
TI: 95mm3 (therefore 95 x 0.835 = 79.3mg/stroke) at 3000rpm= 791.2 us
SOI: 70mg at 3000rpm = 8 degrees advance
So I convert my 3000rpm to degrees,
so that's 50tr/sec, 1tr = 0.20sec (20,000us); knowing that 1 tr is 360 degrees, so it will take 55.5 us for 1 degree
For an injection time of 791.2us at 3000rpm it takes 14.25 degrees
I get my EOI by adding my TI (in degrees of course) to my advance which was 8 degrees = 6.25 degrees
knowing that we can reach an EOI ranging between 8-10 degrees
If I make a larger request in mg then I modify my TI by extrapolating the base values, then my calculation above EOI to check am I correct?
thank you in advance for your help
usualy for this ecu (stage1) You dont need big adjustments in SOI. normaly - 5-10%. usually from factory soi maps are +/- ok.
check shape of map (SOI) if soi values are reducing in higher injection, than You need to adjust that map. Also check soi limiters.
I suggest to work more on torque limiters, gear limiters.
