Debate y preguntas relacionadas con el curso Sistemas de fontanería para deportes de motor.
Anyone know where i cant find injector deadtimes for the bosch 1200cc injectors? cant seem to find it anywhere
I dont think Bosch even make a 1200cc injector? Possibly you have some smaller injector that has been modified to flow 1200cc in which case you would need to either test yourself or ask the company that modified it for their test data.
https://www.speeding.no/p/drivstoff-system-an-koblinger/drivstoff-system/dyser-og-tilbehor/dyser-1588/bosch-1200cc-dyse.html this is the injectors. they are modified from seller yes..
Since you're dealing with a modified injector, unless the person modifying it is equipped to provide you with accurate data, you're in a tough spot as not having accurate generally leads to unexpected and undesirable tuning behavior.
Personally I don't tune injectors if I can't get proper data for them, but you could start with Bosch 1000cc data and attempt to work from there.
Mike McGinnis i got settings from another guy running these injectors! fingers crossed
