Dynojet 224xlc vs Mainline 2WD600L dyno
3538 Vistas
Which dyno is better overall? both of them are load bearing dyno, but each one have its own design. Dynojet is single roller and mainline is double roller. I have not tried them personally , I am looking for an opinion from someone who have used them.
I have a double roller Mustang Dyno, and one thing that I don't like is that the car is sitting lower than the normal height it has been adjusted to when on the road. Maybe like 3 inches. So if you do a lot of very lowered car with agressive sideskirts/bodykits, or exhaust that are very low, you could have clearance issue. I had to raise a couple of cars to install them on the dyno. Also makes it a bit harder to strap.
But one thing I like is that I've never had issues with traction.
