G4+ Force GDI
2620 Vistas
Hi. I want to use this ECU on Audi RS4 B7 with V8 FSI engine. Can I use two Link G4 Force GDI in pair and if it possible, how they connect with each other?
Not recommended, there is no way to link them so they would have to be adjusted separately. I think you would be wiser to look for an ecu that can do 8cyl GDI natively.
Thank you!
