G4X Ghost cam
2288 Vistas
has anyone had any luck with successfully setting up a ghost cam with the G4X, the G4+ method from what i can tell has been removed. Thanks!
yes no issues use a dual ignition map and set the table parameters up the same as the old idle ignition table was
Regards Ross
