Link ECU and Traction Control on R34GTT
2754 Vistas
I have a Link G4X and it is set up with the basics all working on my R34GTT, however, the TCS and Slip lights are permanently lit up. I'm told that Link doesn't support the stock TCS/Slip system and that i would have to install separate wheel speed sensors (in addition to the ABS ones) ... and even then, the TCS and Slip warning lights would remain lit?? (which is an MOT failure here in the UK). I've seen a few discussions regarding this on a 350z, but not sure if anyone has found a workaround on a Skyline?
thanks,
Hello the easy fix is to make the lights go operate an aux output until you can work out a permanent fix
Regards ross
Hi, Thanks for this ... although I must admit I'm not completely clear what you mean?
