LINK G4+ VTEC
3430 Vistas
Hello there , I am new to the environment of the link g4 software and i'm having a hard time finding the VTEC settings. Can you help me locate them?
Thank you.
There aren't specifically 'VTEC' settings. You can just setup an Aux Output and select 'CAM Switched' as the type. This will give you access to several switching conditions. Normally you'd use this to select an RPM switch point and alternatively you may include a second MAP or TPS parameter to offer load and rpm windowing for the VTEC point.
Thanks Andre!:)
