Motorsport functions
1882 Vistas
Hi, im trying to get my antilag working on my evo 8 with link g4x ecu. It was working, but I since adjusted settings for idle control for nct (yearly inspection) and can't seem to get it to work again now, when I turn it on via flick switch, the software shows active, but its not doing anything when I rev the car up etc. I tried changing all idle settings back to the way they where but no difference. Also can flat foot shift be set up via a clutch switch? Any help much appreciated.
Attach the tune and a log of you activating als. You will have to put them inside a zip folder to attach here.
