Nissan VQ35DE VVT Setup
3284 Vistas
Good Afternoon,
Can anyone tell me how to setup VVT for a 2003 Nissan VQ35DE engine? I am not sure which digital inputs and aux inputs to use and what their settings should be in order to properly connect and control VVT. I am using the Link G4 + Fury with the latest PCLink Engine Management software.
Best,
Tom
Page below from the help file should cover most of it, this is for the model that has 4 x variable cams, if yours only has the variable intake then you just dont need two of the DI's and Auxes. The RH intake cam needs to be connected to trigger 2, the other cams can be connected to DI1-4 and Aux 1-4 in any order. Also, there are two 350Z base maps supplied in the software (1 for 2 x VVT cams, the other for 4 x VVT) that you can either load into your fury or just copy the bits you need.
Excellent! Thank you very much for the info. It worked perfectly.
Best,
Tom
