Samsonas S6 Gearbox and LinkG4+ Plug in with shift cut
2903 Vistas
Footage from the weekend at Phillip Island of a mates car that I did the Shift Cut setup in.
https://www.youtube.com/watch?v=5Yjo5KDVfvA
Very impressive -- it takes very little force to trigger to shift cut!
Hi David,
For some reason I missed this response. I actually had to tone down the trigger a bit, as well as train the driver on how to use the box, as he had a habit of holding on to the lever when he wasn't shifting, this would trigger the cut and either shift when he didn't plan to, if there was enough load on the lever, or just send us through the windscreen as the hard cut would enable.
