Thunder Progressive Nitrous Control??
2260 Vistas
Is there anyway to setup a progressive nitrous controller with Thunder Ecu?
It isn't a function as such, however you could use the thunder to control the nitrous solenoid using a PWM output and set up a table of duty cycle to achieve that sort of effect. It would come down to the capability of your nitrous system to a degree too.
