C125 Can Message to M1 on 0x07F0
2642 Vistas
Hi,
I am trying to send a momentary switch on standard 0x07F0 to M1 Driver Switch 1. I can choose the CAN message in Driver 1 Switch menu but can't see any values when switch state changes( i can see the Sw state in C125 working perfectly normal on chanels Monitor) all othe messages sent on 0x07F0 from C125( temps..press, speed , custom counter ) are working perfect. Does the M1 FIRMWARE expect a Multiplier(..divisor or adder) for Swicth status/ or value( send as mV?)
Ps.in C125 sw states are 0 and 1
Thank you
The value should show up as 0.001V on the driver switch. Make sure you are displaying 3 decimal digits.
i have been known to multiply the output value on the dash by 100 or 1000 to make it easier to handle
Hi Claudiu,
This document should assist.
  • MoTeC-Dash-to-M1-CAN-Communications-v3.pdf
  • Solo los miembros Gold pueden descargar archivos adjuntos. Obtenga más información sobre cómo convertirse en miembro Gold aquí.
Thank you everybody!!!
As i suspected a multiplier was needed to recieve message as mV value. My mistake was using faling edge and it needs rising edge.
