DBW Idle oscillation problem GPA
Módulo correspondiente: Funciones adicionales > Control de velocidad de ralentí
Debate y preguntas relacionadas con el curso Tutorial de software MoTeC M1.
1203 Vistas
Hi
I have problem with setting up idle control DBW
TB48DE engine with LS3 Throttle and pedal.
Motec m130 GPA
When engine decelerates clutch engaged
Idle state: enable
Throttle aim state: pedal
RPM start to oscillate and some time engine stalls
After I change the idle throttle maximum from 45% to 30% it improved better and throttle aim state shows IDLE and less PEDAL.
My problem is when the aim state charges to Pedal how to solve it ?
Thanks in advance
Hi,
Can you please provide logging of this thanks.
Unfortunately i don't have any at this time.
If you kindly explain to me why is throttle aim state is changing to pedal, will help me to understand the system.
