Time based boost control linked to a 9 postion switch.
Debate y preguntas relacionadas con el curso Tutorial de software MoTeC M1.
2434 Vistas
Hey Guys. Just in the process of setting up a M150 GPR, C127, PDM and Keypad. We're looking for a more user friendly way of tuning boost delivery to suit track conditions besides the Race time boost limit in Race Functions. Ultimately a 3D boost aim table would be best with one axis linked to a 9 position switch and the other axis a User timer (secs). Is it possible to do this with the dash software somehow or is a custom M1 package my only option?
Cheers Ryan
The 9 position switch is easy since this functionality is already implemented. You can use the 9 position switch as a driver switch and use this to affect the % of your main boost aim table. Think of it as a trim rather than directly affecting where you are in the boost aim table. The timer functionality might be a bit tougher. I'm not aware of a way of implementing a timer other than the already available race time function. Is there a reason this won't work for you?
Thanks for the reply Andre. Yes the race time function will work fine, but will require the laptop to make adjustments, it would be nice to have 9 different options available with a driver switch.
Probably should've mentioned the car is high hp AWD 33GTR so using vehicle speed probably isn't the best option in the event of wheelspin as we know.
