Safely setting base parameters with higher compression and aggressive camshaft
Ajuste del control de levas variable
Debate y preguntas relacionadas con el curso de ajuste del control de levas variables.
1613 Vistas
If I've recently had my ej255 modified with GSC stage 1 camshafts and the compression raised from 8.4:1 up to 9.1:1 what do I need to do to to ensure that my startup map won't allow the AVCS system to put me in a situation where the valves interfere with the pistons?
Piston to valve clearance should be checked during assembly.
If the cam actuators could potentially allow contact, this is a mechanical issue not something you can tune around.
Sometimes limiters are fitted inside the cam actuators to reduce the range of advance or retard.
