Emtron Step 3 Base Table Configuration
Ajuste práctico independiente
1990 Vistas
Hi,
My 2009 JDM Spec C STi has a factory installed manifold mounted air temperature sensor in addition to the MAF air temperature sensor. I would like to clarify which table I should use for charge temperature fuel compensations; is it the Charge Temperature Comp Table 1 or the Charge Temperature Estimate Table.
charge temperature estimation table would be what i would be altering
Regards Ross
