05 5.3 ls stage 1 cam idle problems
3457 Vistas
after start up it idles up then sharply drops to almost nothing ,sometimes it dies . only on start up. if it doesnt die it picks back up and idles fine
Lambda ?
Immediately after the cam' swap? Fuel pressure? Manifold pressure? Electronic or mechanical throttle? Vacuum assisted brakes? Other details?
