2013 zl1 camaro tuning help
3192 Vistas
I've got a customers 2013 zl1 camaro and need a little help tuning. heres the build - cold air intake , headers , gt14 lingenfelter cam , lingenfelter ported heads 9.55 bottom pully(23%) and 2.55 supercharger pully, meth injection , larger injectors
The problem is its great at 60ft times (1.70) but seems to not have great top end pull 1/4 mile times are 11:4 but only 114mph , seems to not run clean on top end , slight sputter at times
I believe there is a timing issue possibly.
AFR 11.6 at full throttle , no KR while running the meth and only a bit at initial full throttle with out meth.
any info on what to look for in the data log or tune would be great . we have to road tune as the closest dyno is a 9 hr road trip
I cant seem to attatch data log or tune???
