4age Potential Trigger issues
812 Vistas
Hi all,
Helping a friend to get his first startup done on his 4AGE 20v blacktop project and having some issues.
Car is setup using Monsoon x , Link Canlambda, 1nz COPs using factory distributor with the 24 tooth for crank and single tooth for sync.
I used a base tune from link from a few years ago and setup all the I/Os and setup the sensors . (one thing to note is the onboard MAP will not sync due to it being too far out of range but not sure if this will be related as using TPS vs engine speed for fuel table.)
Whilst cranking we are loosing RPM signal, have attached Pictures of trigger settigs, trigger scope and a log of cranking and it is logging trigger 1 faults.
With current setup we seem to be getting a pulse to the timing light and have set the base timing off the starter, but injectors and coils are switching off due to trigger fault.
Have tried another distributor with same result.
Hope someone can see something glaringly obvious that we have missed.
Distributor is wired as per image below now, on first cranking to try setup timing it was wired incorrectly but am currently unable to confirm that wiring now.
Turns out I had set the trigger 1 as a crank signal , switched it to cam where it was supposed to be and we have it sorted.
