Acceleration measurment - no access to dyno
2935 Vistas
Hi
Does anyone of you have an experience using Vbox , Gtech or something else to measure acceleration for tuning purposes ?
We are mostly tuning OEM , Megasquirt, AEM and Vems
The reason why I am trying to find a good solution for acceleration measurement is because I live in Iceland and unfortunately we do not have a dyno on the island.
regards
Gudmundur
You'll need some nice flat straight roads.
Take some datalogs at as higher rate as possible.
Then dump the logs into virtual Dyno
http://www.virtualdyno.net/
Dont expect enough accuracy to be able to fine tune ignition timing etc though.
