Adaptronic modular ecu for FD rx7 13b EP single turbo - idle and enrichment
2739 Vistas
Hi,
Has anybody set up both the idle and enrichment on this platform of ecu?
I haven't used the closed loop control before but the open loop is still a little off so when it is in closed loop it is better but still idles high like 1400 rpm but the target is 1000rpm.
Also the enrichment i have copied from the base map set up as a guide and requires you to log various rpm points vs TP . Then these number are placed in the table and it references from them to make corrections ( named predicted map ).
It then it has a transition time from map prediction number in ms so this is currently set to 200.
Then there is a tps rate to trigger enrichment with TPS overall percentage and sensitivity in % / sec in which i cannot get me head around as the base map numbering starts from ( 50 then goes to 300 and is in the sensitivity % / sec table )
Fnally there is a percentage async table to fill out but i think this is a bit low so i have increased these numbers as i did find out some info on one of the adaptronic videos.
Any info would be great as i am not use to using this ecu but have navigated this far
Thx
