aem X series can setup
2933 Vistas
good morning
have a link ecu extreme and an aem xseries wideband do not have the canf plug but would like to wire in to can h and can l
could anyone assist in the setup, do i just need to just connect the wires or i need some kind of hub
regards
marcel
Correct, you dont need a hub, just connect CAN H & L (AEM call it AEMnet + & -). You will want to include a termination resistor at the AEM end of the CAN bus somewhere (ECU has one built in for one end).
Set up info is in the PC Link help file under CAN > Device specific CAN Information.
