ARM 4CH UEGO connection to EMTRON KV8
2720 Vistas
Hi Guys,
I have never connected a CAN device and wondered if anyone can explain how I go about connecting this system... wires and connectors have been run to ecu but I do not understand how to connect and make the ARM protocol communicate with my ecu???
So firstly where do I connect my AEM wires to the ecu?? CAN HI/LO??? then what is expected to get them both communicating.
Many thanks for any help you guys can give.
Please see attachments
CAN+ to CAN1 H (or CAN2 H)
CAN- to CAN1 L (or CAN2 L)
Then, in your ECU, you will have to configure the can protocol (APPENDIX A / page 19 in the instruction manual)
Thanks that's the reassurance I was after :)
