Can't get a trigger signal (emu black, 1jz gte non vvti)
2114 Vistas
Hello everyone,
I'am new in the world of tuning so i hope it's an easy fix, and i dont tire you with stupid questions.
I cant get a good trigger signal. The weirdest thing is, it syncronised ones and never again..
I got an basemap from ecumaster and changed it a little to fit my application (not the trigger settings).
Do you guys have any idea what i could be?
I have added the tune to this post.
Thanks in advance!
I dont know if you can see the log, but the one moment it got a trigger signal was at 8:40
  • 1jz-gte-non-vvti-doesnt-start-no-trigger-signal.emub
There is a built-in scope in the ECU Master Black, it could help you diagnose what signal is missing for the ECU to sync.
Thanks for your reply, i´ve figured it out.
Apparently i made a mistake wiring te coils into ecu.
