CDi Terminals
2141 Vistas
I'm in the need for some new terminal pins for the loom side connection to the CDi.
Does anyone recognise the manufacturer of these at all please?
Dave
A photo of the actual connector or the brand/model of the cdi would be more useful.
M&W, Autronic, and the most of the Motec ones use econoseal III from memory.
Hi Adam,
Didn't the photos come through in my first post? The CDi is a Yamaha 'bike one
Dave
There are two photos of the terminal. No photo of the connector they are from.
How's this:
Dave
Sorry, that is not one I recognise at all. It looks kind of Sumitomo or Furukawa ish, but not any of the common series you see in cars.
I would try emailing pics to Corsa Technic and Cycle terminal since they do a lot more bike stuff to see if either of them recognise it.
Thanks for checking Adam. I've dropped Corsa Technic a line; I'm not sure if Cycleterminal are still in business as I tried contacting them a couple of months back and heard nothing?
Dave
An update to close off this thread.
I got hold of both Cycleterminal and Corsa Technic, and Eastern Beaver and between them we managed to get these connectors and terminal pins identified - the connector is a Mitsubishi connector with Furukawa DEW terminal pins.
Dave
