Confusing problem: Intermittent Lean Condition Above 4000rpm
922 Vistas
Intermittent Lean Condition at WOT Above 4000rpm - Renault Megane 2 RS
I’m chasing a strange intermittent issue on my Renault Megane 2 RS - running the OEM Sagem S3000 ECU.
I use the car predominantly for track purposes. So it’s usually always driving at WOT - except to/from the track.
What the issue is:
SOMETIMES,
  • When the engine is under 4000 RPM, Lambda is under 0.80.
  • As RPM increases (from 4000 RPM upward), Lambda progressively starts to lean out.
  • Can reach 0.90-1.00 Lambda by the limiter.
  • If continuing to drive like this, anti-knock correction increases and continues increasing under sustained load. The AFR rises first, then knock increases afterwards.
  • Engine still feels strong.
  • No misfires logged.
  • No obvious drivability issues.
However, as mentioned - this only happens sometimes. When it does, it would behave like this for the entire session on track (+- 15 mins), and it’s observed from the first pull over 4000 RPM.
When this happens, I come into the pits. Then, when I go out again later (+- an hour later) it might, or might not, happen.
If it doesn’t happen, then:
  • Regardless of RPM, Lambda operates between 0.72-0.80 throughout the session.
  • Knock correction remains very low (under 1 deg) / not at all.
  • Car feels no stronger or different than during the lean condition.
Strange Part:
The car can be:
  • Lean one session.
  • Rich the next session.
  • Lean again later. Or, rich, rich, lean.
  • Or, any combination of this.
This all happens on the same day.
Behaviour doesn’t change mid-session (i.e. It doesn’t go rich → lean mid session). The car’s behaviour is established from when the car is started for the session.
What I’ve Checked:
  • No misfire faults logged.
  • Fuel pump is oversized for the application.
  • Fuel tank level does not appear to correlate with the issue.
  • Battery voltage appears normal.
  • Pump voltage appears stable.
  • Fuel pump current only varies slightly (roughly 12.3-12.7A at ~13.3V).
  • IAT remains steady without much change.
ECU Resets:
I’ve tried resetting all of these (granted, at the same time) - full learning reset:
  • Idle regulation reset.
  • Adaptation reset.
  • Torque meter reset.
Results are inconsistent.
No clear pattern.
Logging Observations:
Comparing lean and rich sessions:
  • Air mass appears very similar.
  • Boost pressure appears very similar.
  • Injector pulse width appears broadly similar.
  • Engine torque estimates appear broadly similar.
Yet lambda can be dramatically different.
What I DON’T Have:
Unfortunately I do not have:
  • Fuel pressure logging.
  • Commanded fuel mass.
  • Lambda target (my wideband AFR sensor for logging is an aftermarket installation).
Which makes it difficult to determine whether:
  • The ECU is commanding less fuel, or
  • The ECU is commanding normal fuel but the engine is receiving less fuel.
  • My Current Thinking
    Fuel delivery issue
  • Fuel pressure variation.
  • Regulator issue.
  • Injector flow issue.
  • Something the ECU cannot see.
or
ECU strategy/calculation issue
  • Different fueling state.
  • Different compensation state.
  • Sensor plausibility issue.
  • Something causing the ECU to calculate fueling differently despite similar logged operating conditions.
Has anyone seen similar behaviour before? I’d appreciate any help.
