Correctly Failing Maf VY LS1 HP Tuners
1803 Vistas
hi guys,
so many conflicting answers to this one over the net and HP Tuners forums
When converting to SD on a LS1, do the DTC code p0101, p0102, p0103 need to be set to no MIL or MIL on first error? along with MAF frequency fail point set to 0HZ
Logically I think that no MIL on first error makes sense, as there still needs to ne a DTC in order for the MAF to fail out correctly?
what is correct?
