Decel fuelling problem / Link G4+ / R33
1903 Vistas
Hi
I am struggling with mixture going rich in deceleration, transient condition.
Usually this would not be of concern, in this case it is, because the vehicle has to pass EURO 3 homologation test and every little bit of HC and CO must be reduced.
Is it possible to have decel enleanment prior to overrun fuel cut, or is it physically a given fact due to the remaining fuel film being drawn in?
Thanks in advance for your help.
D
G4+ didnt have any fuel film/wall wetting type compensation - or even a basic decel enleanment type function at all. It is not something I have ever needed to worry about personally so I dont have any solid experience to share - but one thought I had is you could possibly improve the situation by using a 4D fuel compensation with TPS or MAP delta on one axis and maybe a timer on the other to pull fuel out for a short time after a fast throttle reduction.
Hi Adam,
Thx for the answer. I do have a 4D table for TPS set up, perhaps it needs optimizing?
Could you take a look at how I set it up and some help on the timer example you mentioned?
I could send you the cal via email.
Thank you for the support.
D
You can attach the cal here or you could send me a PM on the Link forum. Would prefer not to post my email address on a public forum for spambots etc.
