Diesel injection timing calculator
2720 Vistas
Hi My name is Truman
Just finished the diesel training course.
I was wondering if anyone has or knows where to get a diesel injection timing calculator to calculate % of pulse width of TDC? Working on a Ram ecodiesel. Sure would be nice to have something to do the main basics.
Any other ideas?
Attached are the layout of the tables I am working with.
Just noticed I put the pressure chart in psi. I am attaching one in Kpa.
Can you elaborate more into what you need to know. I do not understand what you are seeking for.
I am looking for a spreadsheet or software that I can enter the given tables in to figure out the main timing before top dead center. see attached spread sheet for duramax engines. I want the same thing except if you notice the axis are wrong for the ecodiesel. I need one that I can change axis to match whatever i am working on.
  • Timing-Calculator-LMM-charts-filled.xls
Who has got a timing calculator spreadsheet for a 2.8l duramax
