Ecutek Lager Injector Calibration - FT86
1377 Vistas
Hi Guys, im adjusting the injector scaling for a Turbocharged Toyota 86 with Ecutek.
New injectors are FIC 850cc (Datasheet attached)
Following manual instructions, i have to rescale the following maps:
 Port Injector Scaling:
The datasheet specify flow of 845cc at 3 bar, 976cc at 4 bar , and 1091cc at 5 bar, which should i use here ?
 Injector Opening Time Compensation
I have this information in the datasheet, but again, its specified for different base fuel pressures
What is the base fuel pressure in a stock FT86 fuel pump ?
Thanks !
Thanks for your input Mahem, Im getting contradictory information regarding stock fuel pump pressure.
People in the FT86 forum swear nominal pressure @ 57psi
ChatGPT on the other side say 43.5psi lol
thats why im asking here, if im lucky i cant get first hand info form somebody with experience in this platform
Stock fuel pump is 57psi nominal at the Fuel rail. The guy on ft86 forum tapped into the fuel rail as you can read in the article attached here.
Thank you !
