EMUPRO IGNITION OUTPUT
1695 Vistas
Hello everyone,
Planning to go with an emupro 8 in to a porsche 964 3.6L dual spark plug per cyl. Trying to take everything in consideration and thinking about converting to coil over plug with some beru active coils.
Does any one knows if the ecu can handle 2 coils on thesame signal output?
Thanks in advance
Separate outputs are required to fire coils at different times, but when firing 2 coils per cylinder at the same time, the main constraint is current handling of the ECU output. This is noted in the pinout:
